valhalla360
Aug 03, 2016Navigator
j-d wrote:
What Todd said... remember gray water that's held very long can get very nasty. Maybe not as nasty as black but still nasty. I try not to put any solids, even rice grains or corn kernels, but it still happens. So you'd need a pump that'll pass those items or a screen arrangement to keep them out of the pump.
Gray water is often nastier.
Unless you put in dual water supply to rinse the gray water out of the bowl, it's going to stink but there goes your water savings.
Reality is you don't use much water for a #1. I'm guessing we don't use much more than a cup per flush. If you are that desperate and in the middle of no where, find a bush and it uses no fresh water.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
