Eskimo007's avatar
Eskimo007
"Groovy" flat fuses VS non-groovy
I recently needed to replace a 40amp DC flat fuse between my RV battery and inverter, and had the hardest time trying to insert the spare fuse that the original owner had provided. Upon (very) close inspection, I noticed that the replacement fuse although the exact same size and appearance as the burnt out one had some grooves on each side, whereas my replacement did not. Needless to say, trying to force the replacement in the holder brought no joy.
Does anyone know what the difference is between the 2 types? I'm thinking maybe slo-blow or not? Looking at the transparent casing of the fuses, I can see the inside is different.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
