teddyu
Apr 02, 2014Explorer
Something is wrong with the GFCI receptacle or its wiring. Pressing the test button DOES NOT induce a ground into the system to trip the GFCI. The test button shunts current from the hot side to the neutral through a current limiting resistor. Conclusion: the GFCI is bad, the neutral is open, or the neutral and ground are reversed - in other words the wiring to the GFCI is messed up. JM2¢...
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
