BFL13
Apr 03, 2014Explorer II
I wonder if the 120v white wire to the converter input is on the power centre negative buss instead of the neutral buss. Or maybe the converter white wire insulation is cut somewhere so that exposed part touches the metal case of the power centre (which is grounded to the Rv frame) on the way to the neutral buss.
