3_tons
Jan 26, 2018Explorer III
I once had this same problem that was near impossible to determine the cause.... After MUCH trial and error experimentation, I finally disconnected all the neutrals in the main panel, then reconnected them one by one until the GFI tripped again...Turned out to be a leaky heating element in the hot water heater - a trace amount of current was passing thru the waters mineral content...
Hope this helps,
3 tons
Hope this helps,
3 tons
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
