Winged_One's avatar
Winged_One
Ground-Neutral Bond clarification needed.
I need a quick clarification on using a Ground-Neutral Bonded (GNB) plug on a Yamaha 3000ISEB (or any inverter type really). Not sure I am understanding something.
When making the GNB plug, does the wire from the trailer have to pass through this GNB plug and into the generator for it to work?
Reading elsewhere on the net, I get the feeling that if I make a GNB for one of the 20 amp receptacles, plug it in, then all my other receptacles (20 amp and 30 amp respectively), will also be bonded. True?
