Just_There's avatar
Just_There
Ground-Neutral bond
Please help me to understand grounding and neutral bonding. This assumes the transfer switch between shore power and generator switches both hot & neutral. This is how I understand it with a big question at the end.
On-board Generator:
Ground, neutral, chassis all bonded together.
Shore power:
Ground wire, neutral bonded & grounded to earth at or upstream of pedestal.
Battery bank:
Negative through shunt, then bonded to chassis.
PV charge controller:
No ground.
Inverter-charger w/ auto transfer switch:
Case bonded to chassis.
¿Neutral & Ground Bonded? Yes/No
