DD716TED's avatar
DD716TED
Ground Wire??
When my TT was new, there was a braided (aircraft type) wire welded to the frame and on the other end was attached to one of the screws on either the black or grey water dump valve... today I noticed due to corrosion it has broken off... Is this some sort of ground / bonding wire and should I replace it?
  • westend wrote:
    If it existed originally, it's probably a good idea to repair it. I would imagine it has something to do with galvanic corrosion, keeping the electrical potentials equal.
    Times two- and it sounds like it worked just as planned, it having decayed rather than the component it was installed to protect. Time to replace it.
  • If it existed originally, it's probably a good idea to repair it. I would imagine it has something to do with galvanic corrosion, keeping the electrical potentials equal.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
