BFL13
Feb 04, 2017Explorer II
pianotuna wrote:
It would, if you fed the charge controller from one of your cornucopia of chargers! Mex made reference to doing this.BFL13 wrote:
http://www.morningstarcorp.com/products/remote-temperature-sensor/
Yes, but does it work over night? :)
Somebody was describing here the other day about how he uses his Morningstar MPPT controller as his converter powered by a 24v power supply simulating a 24v solar panel. He said Morningstar tech support approved this set-up that it would work ok.
You can't do that with a Shunt controller though. They operate by shorting the panel, so it would wreck the power supply input by shorting it.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
