dougrainer
Feb 15, 2022Nomad
If you have water cut offs at the back of the tank, shut them OFF and drain the water heater. Dry up the area and let sit for 24 hours on city water. IF NO LEAK, then the bottom of the water heater tank has a pinhole. Do you have ANY water lines that are routed underneath the water heater? If so, they may be the problem, but you will still have to pull the water heater regardless. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
