dougrainer
Mar 20, 2022Nomad
philh wrote:
Suburban sent out a "refurbished" water heater. Not completely thrilled with that, but it was definitely the water heater had a leak somewhere. I didn't take off the insulation to see what was leaking.
Just very lucky that the leak got bad enough when my wife was mopping the floor and saw water coming from underneath the cabinet. I've gone back to only using my onboard pump.
If the Transmission in your new truck under warranty goes out, you do NOT get a new transmission. It will be a factory rebuilt. True for almost all the more expensive parts under a Vehicle warranty. Odds are that a Suburban rebuilt/refurbished was one that an OEM sent back because OEM's do NOT fix appliances if they find a fault when building the RV. They just swap it out and send the defective appliance back to the Maker for credit. Maybe because of the Pandemic, but I have NEVER heard of a RV appliance maker(Furnace or Water Heater) sending out a refurbished under warranty. They may have done so when the appliance warranty was out but they wanted to do a Goodwill repair. I have 43 years as an RV tech. What is your warranty date on your RV? Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
