wa8yxm
Mar 20, 2022Explorer III
Possible "not the water heater" leak sources
The inlet connections
The outlet connections
The Drain/Anode connection
The TPR valve and it's fitting.
Any pipe fitting NEAR the water heater but not directly connected (Valves, Elbows "T"s and the like)
Finally the tank can spring a leak but I would hope not a new one less the installer wacked it with a punch.
Slow leaks can be mighty hard to track down.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
