BFL13
Jul 03, 2015Explorer II
Still looking good after three hours at 13.2, running 12v loads at times with the solar doing that, while the battery is taking only part of an amp. Now at plus 1.63AH on the Trimetric so I reset it too soon.
The SG was little different at the end of Bulk from what it was an hour before that when voltage was about 14v. So actually, you could say the batts were full before Bulk ended even though they were taking 13 amps (four 6s) which must have gone off as heat mostly.
I suppose that means my Vabs is too high too. Have to let this run for a few days to prove it out. The 14 day- Forecast is for the same straight through. Yipes! Now heading up to the lake for a swim. Pretty soon we will need JiminDenver's RV solar air-conditioner system :(
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
