JiminDenver
Jul 04, 2015Explorer II
Why wouldn't the voltage come up if the battery was full? What was the banks voltage when you thought it was full? When the controller did finally go to float did the amps drop to near nothing? At that point the battery would be controlling the acceptance rate and if it was full, it should have accepted very little.
You might want to check your water levels if the amps dropped dramatically as soon as it hit float. If the amps didn't drop your battery wasn't full and you need to check your meter.
You could set the absorb set point to a lower voltage and see how it goes. Maybe try leaving as it is and dropping the set point once the meter says the bank is full. Force it into float and see if the amps taper quickly.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
