BFL13
Jul 04, 2015Explorer II
Thanks, so I must be seeing a smaller version of that. (your good work on that screwy 31 reporting did not go to waste!) It's back to the idea you can't fine-tune the solar, so just broad-brush it.
On today's SOC, it is confirmed not as far up as yesterday by seeing more battery amps still being accepted even after the drop to 13.2. Yesterday it was about half and amp but today the Tri is showing 2.4 amps to the battery at 13.2v.
So this is like a mini-absorption stage at the moment till the battery gets to full. As long as it gets there before the big amp draws start from suppertime on, it will work out.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
