pnichols
Jul 04, 2015Explorer II
MEX wrote:
Don't know about floats but assssssssssumptions that a single fixed-point float voltage works in all seasons is absurd.
Right you are.
That's why I disconnect the RV batteries from the always-on converter whenever the RV is sitting in the back yard in hot weather.
That's also why I live in Central CA ... so that I don't have to disconnect the RV batteries from the always-on converter due to any concerns about the converter's voltage being too low of a float whenever the RV is sitting in the back yard during our mild winters.
But ..... I figure it's better to use coach batteries that are designed right from the get-go to be floated "nominally and on-average" at 77 degrees F at converter voltages. Well ... at least better to use coach batteries where the manufacturer is willing to state in writing that converter voltages are proper at 77 degrees F.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
