BFL13
Jul 07, 2015Explorer II
JiminDenver wrote:
I didn't want temp comp for camping even though we can see from below freezing to 70 or 80f daily. The battery takes longer to adjust and never sees the extreme of either. I needed it for storage where the temperatures can be in the minus 20's f, or the 100+ f range for extended periods of time. I bought the MS because there were not many options at 60a. A week after I ordered I found EP has a 60a MPPT now but the VOC is limited to the 50v range. It could have been a option had I known about it.
They have changed the spec on the 20 amper too. Wes 42v, then 45v, now it says 50v. I can't tell if that is just new ones or if they have always been good to 50v.
It could explain how that guy ran two 12s in series ok with his. Given that 50v now for the 20amper, it opens a whole new world where you can run a single 24 as before, but can now also choose two 12s in series if you want.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
