I need to remove and clean my Hadley air horn solenoid or replace it. Everything I have read says you have to drain the air tank first. Perhaps a dumb question, but how to you first drain the air tank...
It is a gasser, the only air tank is the one to the airhorns in the upper front of the unit. Horns do not work at all, which is why I need to remove and clean or replace the solenoid.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
