CA_Traveler
Aug 01, 2017Explorer III
I've found that it's unlikely to find a pedestal voltage problem with any of the above suggestions. Adding a load like a ceramic heater and checking the voltage would help. However that also doesn't ensure good voltage later.
Nothing beats a full function power protector like the Progressive Industries units. First they won't connect the rig to shore power if there is any problem at that point. Then they continue to monitor and will disconnect as required. Sure it's more $$ than the 3 light tester but a lot less than replacing your rig electronics plus the ruined camping experience.
The above suggestions will certainly help find some pedestal issues. The 50/20 or 50/30 plus 30/20 adapters are also a good test even for a 50A rig since it at least tests 3 of the 4 50A wires.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
