pianotuna
Nov 28, 2016Nomad III
Hi MEX,
Some LI packages are plug and play. One that I surfed to even has a heater built into the jar. Cost for that one was a mere $10 per amp-hour ($1000 for a 100 amp-hour battery)
My brother managed to destroy one by attempting to charge it when it was too cold. He was intending to do a refresh charge in December on an LI motorcycle battery. He was using the recommended charger from the company.
If I were to go LI, I would certainly try to add automatic generator start to the mix. That won't be easy to do as most of those rely on battery voltage monitoring and with LI there is very little drop.
Then there is the cold weather issue.
Apparently LI has zero tolerance for abuse. Do it once, and only once and you get to replace an extremely expensive battery bank.
All in all, I think carbon foam may be a better technology. But there is no history and very few users at the moment.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
