KJINTF
Nov 28, 2016Explorer
horton
Take a look at Elite Power Solutions
They carry the GBS line which is very good
GOOGLE Prismatic cells
YES the cells SHOULD be strapped together
Each and every installation will be different - showing mine will confuse most
I would suggest you first write down and understand exactly what it is you want from your battery bank. I find when it's on paper virtual or not it's far easier to visualize what the solution could be.
Not knowing your electronics design capabilities
I would suggest you follow Boating forums, Electric car forums, and a few EE blogs. Remember the applications are ALL different. An electric car draws way more than "C" while a typical house battery in an RV is far below "C".
Can't remember the boater in Maine (the link has been posted here several times in the past) that has a nice blog on LiFEPO4 battery pack being used in a similar application as a RV house battery.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
