hbski
Oct 22, 2015Explorer
I think that "dead wrong" is a bit hyperbolic. By and large his major tenets are large enough wiring for minimal voltage drop, charging at the BATTERY manufacturer's spec'd voltage, measure voltage at the batteries and use a decent controller.
Not exactly controversial ideas.
Part of the problem with charging batteries is that the only voltage that matters to the battery is the difference between it's current voltage and the charge voltage.
Taking 12.5 as an example and simplifying things, if your charge voltage is 14V and you have a 3% drop to the batteries (-0.42V) you are losing 0.42V/(14V-12.5V) = 0.28 or 28% of your potential energy that could be going into the batteries.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
