N8GS
Oct 23, 2015Explorer
pianotuna wrote:
Some of handy bob is dead wrong. I've included a much better less wordy and less opinionated link below.
Here is a simple flow chart.
Budget-->Energy Audit-->Battery bank size-->number of watts-->PWM or MPPT. What ever type of controller is chosen, make sure it has adjustable set points and a temperature probe that is on the battery.
If you use solar as a battery charger, one rule of thumb is between 60 and 150 watts of panels per 100 amp-hours of storage. The smaller the battery bank the higher the wattage needed (per 100 amp-hours). Here is a link to the rather special spreadsheet which includes an energy audit, that N8GS has created to help size solar battery charging systems!
solar spreadsheet by N8GS
If you full time or use an inverter lots, then populate the entire unshaded area of the roof with panels. I'm considering replacing my awning with solar panels.
For a nice explanation of solar, try this link:
Golden rules of solar
Handy Bob's info was good when written but today the available parts are much different and the solar industry has matured.
For those wondering about what size wire to use please refer to my spreadsheet it has an extensive wire calculator page that includes voltage drop and how much energy is wasted in heating the wire.
Don - I'm glad to see that you are still recommending my spreadsheet.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
