Old_Islander
Jun 12, 2018Explorer
NEOK wrote:I thought that might be the problem, but I've experimented and it does it occasionally on a fully charged battery, when the truck engine is running, or when on shore power.
You mentioned you may be having battery problems. Does the yellow light act the same when you are plugged in to shore power?
So I guess I'll start with the least expensive stuff... The cable between hand hand controller and the relay module is a plain old telephone cable (about 6' long) that looks like the pic below. If that doesn't fix it (and it probably won't...), then I'll try to find a replacement hand controller. :(
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
