MEXICOWANDERER
Oct 02, 2014Explorer
when a one amp or greater potential Wall Wart is putting out 15 volts a silicon diode is warranted. When the wall wart is rated for 13.5 to 14 volts a SHOTTKY is mandatory.
A rectified 800 ma transformer wall wart is ideal. Open circuit voltage may be as high as 18.0 but operating through the impedance of a single battery finishing voltage will be around 13.45 A group 24 slightly higher a group 29, 30, or 31 slightly lower. An AGM battery has not be tested yet.....forthcoming.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
