RSD559
Mar 22, 2018Explorer
If the Predator is like my Champion, it uses gravity to feed the carburetor. So as soon as you put gas in, you primed it for the fast start. I don't know if it has a fuel pump or uses gravity. Just a possibility.
And if it does use gravity, like my Champion, you can use the procedure from this forum to add an external tank, if you would like.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
