dangerbird
Jun 17, 2022Explorer
I've had one for several years that I use at the house for running water and heat when power is out. Use it a lot for yardwork in the woods. Power quality is excellent. Regardless of load, the frequency is dead steady at 60.02 Hz. Shows a perfect sine wave on an oscilloscope. Great for electronics and my ham radio gear. My only complaint is that the ignition switch is in combination with the fuel shutoff. This makes it impossible to turn only the fuel off to run the gas out of the carburetor. I added a bypass switch for the ignition so it will run with the fuel valve closed. I always run the carb dry after use. It has never failed to start on the first pull of the rope. The original starter battery didn't last very long. You can easily have a conversation right next to it at full load. It's a bit hefty. Any heavier and I would ask for help lifting it into the pickup bed. Hope this helps.
Carl, WG2E
Carl, WG2E
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
