Boomerweps
Oct 20, 2020Explorer
Rover_Bill wrote:Boomerweps wrote::?
Clogged toilet valve supply...
Does your toilet use HOT water for flushing? I hope you're using an inline water filter on your water supply - both city water connection and to fill your fresh water tank. :W
Normally use an inline filter.
The theory was draining with the low point drains with the water heater not bypassed can pull crud in to the cold water line. I don’t know, but the crud looked suspiciously like that seen on the anode rod previously.
I did not use a filter when filling the tank when I was adding bleach for sanitizing.
It could have been an algae from the water setting for most of five months BUT the water stank of chlorine with initial use when I finally went camping.
Won’t dewinterize until within days of camping next time.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
