mchero
Jun 13, 2017Explorer
Nothing unusual. I found a 12 volt bus bar that had a number of common, or negative leads connected to it. EVERY NUT was just finger tight! It was under a drawer. Fed the light over the sink, pump switch and furnace on the full wall slide!
I also occasionally check all connections behind the A.C. panel. Once found a common lead on the buss bar loose and starting to overheat and discolor.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
