donn0128
Jul 18, 2015Explorer II
30 amps means you have maybe 25 amps total.
15 for the roof AC
7 each for the refer and water heater. Your overloaded. Make sure your water heater and refer are manually forced to gas run a heavy duty extension cord for the window AC. You should be OK. BTW, typical roof top AC is lucky to cool an RV down to about 15 degrees below outside temps.
15 for the roof AC
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
