j-d
Jul 18, 2015Explorer II
How old is this travel trailer? If the A/C coils haven't been cleaned, you may be able to get some relief if you so. Up on top, the plastic shroud comes off. There'll be a fan blade facing the front of a coil at the back end of the unit. Hose that one out. Then the sheet metal that forms the nose of the A/C comes off and you clean it. More carefully since you can get water down into the trailer. You can also clean the condensate drain pan and be sure its two outlets are open so that water drains out onto the trailer roof.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
