diveman52
Apr 11, 2014Explorer
OP said they never dry camp so I assume they only want to use the inverter during there traveling between point A and point B.
If this is the case why not use your existing converter in place and get a Xantrex 1000 watt inverter. It will be more than enough. Your two 12 volt will be fine just make sure you have a charge line from the tow vehicle to TT. The residential Freig will not cycle much if it's already cold when leaving for your trip.
You will be fine.
You will be fine.
