Gdetrailer
Apr 11, 2014Explorer III
GordonThree wrote:
I installed an inverter, but still have my ammonia absorption fridge.
I too had considered the Tripp Lite... I know the brand well from the information technology industry.
A few things I didn't like about the tripp lite was lack of rv specific features; especially low battery voltage cut out. it will suck your batteries all the way to 0 if you let it. more expensive inverters like xantrex and magnum have protection against that sort of thing.
the charger is also a bit weak in the tripp lite. if you're getting a 2000 watt+ inverter, you need 600+ amp-hours of battery bank, and with that much battery, you want a 100+ amp charger... like the Magnum's 125A 4-stage charger.
as to how to wire it, instructions are provided in the installation manual. I can help with specific questions if you like.
many folks recommend just wiring the inverter to the batteries, and plugging your rv's power cord into the inverter. I went a step further and utilized the transfer switch built into my magnum. the power cord for the rv (shore power) connects to the magnum's input, and then the magnum is connected to the breaker panel where the rv power cord was connected before.
I like 12v batteries myself, big group 31 agm to be specific. lots of folks prefer 6v golf-cart batteries. it all depends how much space you have, how many batteries can you fit in there? if I had all the space of a huge motor home, I'd go with 2 volt "jars" instead of 6 or 12v batteries... the jars are designed for massive current and very long life, compared to 6 or 12v batteries.
6 or 12, you'll want at least 4 batteries to have enough amps to satisfy that inverter... do you have that much room?
:h
Really?
Honestly, I don't know where folks come up with these ideas AND POSTING such drivel WITHOUT truely taking a few minutes to FULLY research..
Tripplite like ALL other inverters DOES have 12V LOW VOLTAGE shutdown protection..
From the FIRST PAGE of the Tripplite manual for my PV1250..
And I quote..
HERE
Congratulations! You’ve purchased the most advanced, feature-rich
Inverter designed as a mobile energy source for your vehicle.
PowerVerter Inverters efficiently convert DC (battery) power into
120V AC (household) power, allowing you to use equipment you
commonly use at home—appliances, entertainment systems, computers,
power tools and more—while cruising the open road.
PowerVerter Inverters, through a high-efficiency conversion
process and a charge conservation setting, draw the highest
level of performance from your batteries without overtaxing them, lengthening their service life. An automatic low battery shutdown feature ensures you'll always have plenty of power for starting purposes.
You can also keep those group 31 AGMs, nothing than a very expensive yuppy toy.. especially with what the OP is needing which is for only 4-5 hr DRIVE.. Heck even a simple group 27 RV/marine battery will suffice for what they are wanting to do..
Why FORCE folks to spending top dollar on something (a expensive AGM)that is not needed.
The OP CAN EASILY go 12-24 hrs without an inverter provided they simply do not open the fridge more than a couple of times and they could simply get away with a frozen gallon jug of water in the fridge along with precooled food..
For what it is worth..
I USE a Tripplite PV1250 to run my home fridge conversion while traveling and overnighting.. And I do it ALL on ONE PAIR of Sams 6V GC batts (non AGM)..
We typically spend 10 hrs driving for two days and one overnight stop without power.. The charge line helps to offset the power used by the inverter/fridge. I set my inverter to use the load sense feature which turns the inverter on/off with the fridge compressor demand. I set the inverter to turn on with a 9W load so when I open the fridge door the light inside will trip the inverter on and the light will light up.
The OP could get away with a smaller Tripplite, even the 1000W should be able to start the fridge. Just make sure though you place the inverter CLOSE as possible to the batteris and use LARGE ga wire. I used 1/0 and only have 6ft total wire used (three foot each for pos and neg).
FUSE that wire NEAR the batteries, I used a 200A ANL fuse that is about 18" from the batteries..
The setup is priceless! :D
