westend
Apr 12, 2014Explorer
For reference: I run a small dorm fridge with a 300AH bank and a Xantrex 1000W inverter. It draws 80 w at a 1/4 duty cycle in summer ambient temps. A larger residential fridge will use a bit more power but not much. The locked rotor draw is the reason to use a 1000W+ inverter and the Tripplite should overcome that easily. 4 to 5 hrs, of run time should be easily accomplished with two 12V batteries and the charging of the vehicle.
BTW, you won't miss solar until you have some.:B
