time2roll
Apr 13, 2017Nomad
With further reading inverter does have two pole transfer switch. I still do not recommend using this 30 amp switch in the main 50 amp feed to the main panel.
Manual p11
If spending money consider something like GoPower with a full 50 amp split phase transfer switch.
http://gpelectric.com/products/inverter-charger-ic-series
I see a lot of inverters where the transfer switch has a low rating based on the inverter wattage instead of the circuit that inverter may get connected to.
Personally I like separate components to match what you need and replace only what fails.
Manual p11
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
