Bill_Satellite
Apr 13, 2017Explorer II
CA Traveler wrote:
The open ground could be anywhere including the pedestal.
The shot gun approach might work: Has anything been modified, added, including but not limited to plugs, wiring, etc? Check those areas.
It's not the pedestal as this has been going on for years.
As to the 2nd question, yes, nearly everything in this coach as beed modified, add, adjusted. It's a 1988 with a full remodel in 1994 and many minor modifications so it could be anywhere.
I would think that none of my GCFI's should work. I have 4 GFCI breakers inside the coach plus 1 other plugs with GFCI and all of them work just fine and trip when tested.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
