CA_Traveler
Apr 13, 2017Explorer III
The pedestal CB disconnects only the hot lines. As long as you are plugged in you will have neutral ground bonding back at the service panel.
"This is partly why having L1 connected direct and L2 through the inverter might be causing the trouble because they are not completely isolated."
If this is how it's wired then wire it correctly and see if that resolves the inverter issue.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
