Bill_Satellite
Apr 19, 2017Explorer II
Sorry, I missed your post CA Traveler. The inverter has 2 outputs and each goes to its own individual set of wires, 1 for each circuit. The inputs sending 120V to the inverter from shore is designed for either a 3 wire 20-30 amp circuit input (from my breaker box) or 1 4 wire 50 amp (240 out of phase) circuit. I have talked with others that using 2 3-wire inputs should work just the same as the 50 amp 4 wire since both neutrals and grounds are already connected to the same bus bar in the breaker box.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
