CA_Traveler
Apr 19, 2017Explorer III
From the manual for the 150:
Input AC Source from Dual Input:
The dual input has 2 line inputs, 1 neutral and 1 ground. The two 120Vac lines are in phase and must come from the same source.
To be clear this is your intended configuration and not the split phase 120/240V correct? And you are using 2 3 wire connections for this hookup so you have parallel neutrals and parallel grounds. Correct? Are you sure both hots are from the same 120/240V leg?
Skipping for now my safety concerns about this suggested hookup, etc and trying to help find the problem.
Temporary wiring to isolate the problem: Run 3 wires and only 3 wires from the ATS (you asked about this) to the inverter input. Does it now work OK?
If not remove all output wires but leave the 3 wire input. Does it now work OK?
Is so then connect first one output, OK? Disconnect and then connect the other output. OK? And disconnect means remove all 3 output wires.
If OK then perhaps something is misconnected on the outputs. Further connect 2 completely rig independent output circuits and load them. This should be OK and the same as your bench setup.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
