Bill_Satellite
Apr 19, 2017Explorer II
The problem is that every setup I have tried "works" just fine for a few months. I don't know enough about RV wiring to know what is in phase and what is split phase. With my 50amp coach (50amps of power available on each or 2 separate legs) the only way to send 240V to any device is to supply power from Hot L1 and Hot L2 plus the neutral and ground. If I can get the inverter fixed/replaced I am going to return to the option of tapping into the transfer switch and run a 4 wire (2 hots plus 1 neutral and 1 ground) as the incoming power but I don't believe that this is any different than running 2 3 wire connections to the same ports when that source is the same Hot L1 and Hot L2 with a 2 neutrals and a 2 grounds coming from the same bus bar. It even seems that I could just not connect both neutrals and both grounds in the inverter since they are already connected at the breaker bus bar.
Help!
Help!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
