Artum_Snowbird
Aug 05, 2014Explorer
Converter terminals putting out? Yes... voltage over 13 Volts, almost 14. What is at the battery? 14 should be. 12 or less? One or the other wire from the converter is not tight and connected. Best option, use a jumper cable and connect to the positive battery, and to the positive converter. Did it fix it? Yes.. find the loose positive wire. No.. use the same jumper cable and connect from the negative battery to the converter negative. Did that fix it? Yes.. check the negative wire to the battery. No.. other things. Try that first and see what happens, then call me back.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
