mikestock
Apr 16, 2018Explorer
time2roll wrote:
These GFCI generally trip in excess of 5 mA differential. Could be you each are leaking 2 mA.
I would first try turning off all breakers in the RV except the main and the charging system. See if that eliminates something.
Second I would try using a Battery Minder or Battery Tender brand maintenance charger direct from the outlet to the battery and see if that resolves the issue. The idea is to remove all the RV circuitry from the load circuit.
Otherwise could prove difficult unless you have the keys to all three RVs.
100+ watts solar and a controller could also eliminate the need to plug in.
In which unit? Any two together work okay until the third is added.
The 100 watt solar would be an expensive (I don't boondock) way to solve the symptoms or I have 12 volt/15 amp charger which would also solve the symptoms but not eliminate the problem.
