pianotuna
Apr 16, 2018Nomad III
My point is we need to always treat an electrical connection with respect. GFCI can and do fail. I never assume a circuit is not live. And yes, I've had a shock or two in my life.
If it is raining I plug in wearing rubber boots and silicone gloves. As well I "shuffle" (drag your feet across the ground) as I'm moving to and from the pedestal. If there is water on the ground I prop up the cord to keep it from being submerged.
I'm at a location at the moment where the GFCI prevents me from using the Magnum Inverter charger. So it is back to the OEM converter. It is a pain in the neck not having the load support feature. What is maddening is the Magnum works with some GFCI outlets, but NOT all.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
