Hurricaner
Apr 17, 2018Explorer
The problem is three battery chargers plugged into one GFIC. One charger is fine and two will still be OK but the third adds up to enough ground leakage that the GFIC trips. There is no way around this except adding a parallel GFIC receptacle to split up the chargers.
All switching power supplies(modernconverters, IE battery chargers) leak a small amount of current to ground. This is usually not enough to trip a GFIC but if you have several the additive effect will.
Sam
Sam
