MEXICOWANDERER
May 27, 2013Explorer
Packerfan73,
Many times OEM makes a connection way down inside the opening cut out for the tail light. I have found bad connections after I unfastened the entire tail light assembly and let it hang. Running an exposed new wire may not be the best first option.
Don't let it buffalo you. It can be a real easy fix but you need to check.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 18, 2026
