2oldman's avatar
2oldman
Explorer II
Jul 22, 2014
HD DVR dedicated inverter
I've installed a dedicated inverter for the HD DVR.
I had a spare 2kw (12v) Xantrex, which, amazingly, fired up and worked - with only #10 wires feeding it. There was a 12v socket in the cabinet, but I pulled those wires and put new connectors on them. The receiver draws only 50w, so we're good there. The voltage sits at about 12.2 as shown on the inverter front panel. Normal coach voltage is 12.5. I let it run for quite some time, and nothing's getting hot, so I guess that's good. I thought perhaps the small wires wouldn't even be enough to start the inverter itself, but, no problemo. I've ordered a 350w Samlex to be a permanent install. The 2kw unit is just too big for the cabinet.
That darn receiver will go through an entire boot up of 10 minutes or more for even the slightest power outage.
