nickthehunter
Apr 03, 2024Nomad III
Are you trying to operate it on gas or 120V? Because if you are fulltiming and plugged in you should be operating on 120V and the wires to check for voltage are black and white (not brown). If you are trying to operate on gas then the trouble shooting is a whole different ballgame (I.e.: good battery, good converter, 120V power, fuses at converter, gas source, etc.)
mcnamarac
Apr 03, 2024Explorer II
Thanks for that! Yeah I’m plugged in shore power. Here’s what I’m working with. I’m not getting any voltage off the brown wire, which form other videos is the power wire for these from the main control panel inside the rv at the little red switches for water heater
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
