opnspaces
Apr 03, 2024Navigator III
Unfortunately we really need a model number on that heater if possible. For instance in the 6 gallon models there is a wire color difference between a G6A-3E and a G6A-7E.
Aside from that I would use a small flat blade screwdriver and pop the switch out of the wall panel. Check that 12 volts is getting to the switch and if it's getting through the switch to the downstream side.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
