dougrainer
Sep 18, 2020Nomad
Mont G&J wrote:
Perhaps it's like mine. My T-sat has a selection for 'Furnace' and in that case the furnace will come on and blow out of the lower furnace ducts. Also, I can select 'Auto' and in that case if the T-stat calls for heat the AC comes on and works as a heat pump blowing warm air out the upper AC ducts. If the trailer is warmer than the set temperature the AC blows cold air out of the same upper duct.
Sorry, not correct. AUTO does NOT turn on the Heat Pump function if you have a AC/HP upper unit. ALL AUTO does is allow the system to select the fan speeds and shut the fan OFF when temp is met. You still have to select HEAT PUMP on the wall tstat for the HP to function if you have one. If you do not have a HP display on your tstat, you do not have a HP. Doug
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 29, 2026
