Mont_G_J
Sep 19, 2020Explorer
down home wrote:
Find a good the to sort out the thermostat/controls. Our has two furnaces and two heat pumps. It is cold with the heat pumps selected , the furnaces still come on first to bring the coach up to warmth fast, then shuts off and the heat pumps take over. Our Holiday Rambler Fifth Wheel operated the same way, I believe. And when it gets so cold the heat pumps aren't able to keep up the furnaces kick back in and heat pumps go off. No way a heat pump can blow both hot and cold at the same time, unless it also has heat strip and it is wired cockamamie, with it wired on the wrong side of the thermostat/switches. Heat pumps work in both direction reversing the ac cycle on heat to extract the heat from the air outside and heat the air inside but can only work in one direction at a time.
The OP said it was a new trailer to SIL and was getting heat and AC at the same time out of the overhead ducts. It seems to me the AC is running in the HP mode and the new owner doesn't understand that the air conditioner is capable of producing heat or cold depending on the mode.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 29, 2026
